ABB ACS880 Drive
520
Jun 12, 2024 9:04 am
Cause : Encoder option comm loss comes when encoder feedback not used as actual feedback, or measured motor feedback lost (and parameter 90.45/90.55 is set to Warning).
- Check that the encoder is selected as feedback source in parameter 90.41 or 90.51.
- Check that the encoder interface module is properly seated in its slot.
- Check that the encoder interface module or slot connectors are not damaged.
- To pinpoint the problem, try installing the module into a different slot.
- If the module is installed on an FEA-03 extension adapter, check the fiber optic connections.
