ACS880 Paralleled Inverter Modules Startup?
2 Users
(@twoblocked)
New Member
Newbee here. Hoping for some help from you fine folks. Will be involved with commissioning a couple 1000A ACS880 drives this week. They run 800 hp blowers. They are replacing some ACS800s with 2 parallel connected inverter modules. I expect the ACS880s to be configured the same way. Been looking for particulars in setting up parallel connected inverter modules. All I can find is parameter 95.31 - "Parallel type configuration."
Will each module need the parameters entered separately, the same as if the modules were not paralleled? Same when performing an ID run? Any general of specific info would be helpful.
Please share your drive complete part no.
