ABB ACS880 Drive
295
Jun 15, 2024 5:00 am
Cause : PCB space cooling comes when temperature difference between ambient and drive module PCB space temperature difference has exceeded warning limit.
- Check cooling fan inside the PCB space.
- With parallel-connected modules, check the auxiliary code (format XXXY YYZZ).
- “Y YY” specifies through which BCU control unit channel the fault was received.
