D207 fault in ABB ACS880 drive
Cause : Wrong start sequence comes when drive does not accept a start command because the drive is not ready for the following reasons:
  1. The main power is switched off.
  2. Fieldbus control bits are used in the wrong order.
  3. The upper or lower limit is active.
Check and correct the possible causes for the warning, and then give the start command again.
