FB14 fault in ABB ACS880 drive
Cause : Memory unit FW load failed comes when the memory unit is empty, or contains incompatible or corrupted firmware.
  1. Recycle the power to the control unit.
  2. Check the sticker on the memory unit to confirm that the firmware is compatible with the control unit (ZCU-1x/BCU-x2).
  3. Connect Drive Composer PC tool (version 2.3 or later) to the drive. Select Tools - Recover drive. If the problem persists, replace the memory unit.
