ABB ACS880 Drive
548
Jun 15, 2024 9:44 am
Cause : MF communication loss comes when master/follower communication is lost. On the FDCO module (if present), check that the DDCS link switch is not set to 0 (OFF)
- Check the auxiliary code.
- The code indicates which node address (defined by parameter 160.02 in each supply unit) on the master/follower link is affected.
- Check settings of parameter group 160 DDCS communication.
- Check the cable connections.
- If necessary, replace the cables.
