ABB ACSM1 Drive Programming
Optimize your ABB ACSM1 drive performance by configuring parameters like motor data, control mode, ramp times, and more. This guide provides a comprehensive overview for efficient setup.
Here is step by step programming of ABB ACSM1 drive:
Step 1 – control wiring
Connect all control wiring for start/stop and speed reference. Below image show control wiring of ACSM1 drive.
Step 2 – Power wiring
Connect input power wiring and motor wiring to the drive. Connect input power to L1, L2 & L3 terminal and connect motor wire at U2, V2 & W2 terminal.
Step 3 – Parameters
Below list show all parameter used in ACSM1 drive programming.
Factory Reset
  1604 clear all
Motor data
  9906 …...A
  9907 …...V
  9908 …...Hz
  9909 …...rpm
  9910 …...KW
Control mode
  9905 DTC
    Scaler
  9913 Normal
    Redused
    Standstill
    Advance
Limit
  2001 …...rpm Max speed
  2002 …...rpm Min speed
  2005 …...A Max output A
  2503 …...s Acc time
  2504 …...s Dcc time
Step 4 – Testing and Verification
  1. Start the Motor: Once programming is complete, you can initiate motor operation using the start/stop buttons on the control panel or through external control signals if configured.
  2. Monitor Performance: Observe the motor's operation and verify it functions as intended. If adjustments are needed, return to parameter setting mode and fine-tune the settings.
