F0001 OVERCURRENT Fault in ABB ACSM1 Drive
How can resolve problem F0001 OVERCURRENT Fault in ABB ACSM1 Drive ?
Cause : Output current has exceeded internal fault limit.
Check motor load.
Check acceleration time. See parameter group 25.
Check motor and motor cable (including phasing and delta/star connection).
Check that the start-up data in parameter group 99 corresponds to the motor rating plate.
Check that there are no power factor correction capacitors or surge absorbers in motor cable.
Check encoder cable (including phasing)
