ABB DCS800 drive programming
Optimize your ABB DCS800 drive performance by configuring parameters like motor data, control mode, ramp times, and more. This guide provides a comprehensive overview for efficient setup.
Here is step by step programming of ABB DCS800 drive:
Step 1 – control wiring
Connect all control wiring for start/stop and speed reference. Below image show control wiring of DCS800 drive.
abb dcs800 drive control connection 3 image
Step 2 – Power wiring
Connect input power wiring and motor wiring to the drive. Below image show power wiring of DCS800 drive.
abb dcs800 drive power connection 1 image
Step 3 – Parameters
Below list show all parameter used in DCS800 drive programming.
Motor Data
  99.02 ……V Armature Voltage
  99.03 ……A Armature Current
  99.04 ……rpm Base Speed
  9910 ……V Nominal Mains Voltage
  99.11 ……A Field Current
Start/Stop
  10.15 DI1 Field Start/Stop
  10.16 DI1 Armature Start/Stop
  10.03 Not Used
  10.06 Not Used
  10.08 Not Used
  10.09 Not Used
  1020 Not Used
  10.21 Not Used
Speed Reference
  11.03 2 – AI1
  13.03 1 = 0V-10V Uni
ACC/DEC Time
  22.01 ……s acceleration time 1
  22.02 ……s deceleration time 1
Limits
  20.01 ……rpm Minimum Speed
  22.02 ……rpm Maximum Speed
Step 4 – Testing and Verification
  1. Start the Motor: Once programming is complete, you can initiate motor operation using the start/stop buttons on the control panel or through external control signals if configured.
  2. Monitor Performance: Observe the motor's operation and verify it functions as intended. If adjustments are needed, return to parameter setting mode and fine-tune the settings.
