E02 fault in ABB DCS800 drive
E02 fault in ABB DCS800 drive indicates SDCS-CON-4 ROM memory test error. This means a ROM memory test error with the SDCS-CON-4 control board, suggesting that the control board’s ROM may be faulty or corrupted. This issue can prevent the drive from operating correctly, and it often requires specific attention.
Here’s a troubleshooting approach for this fault:
  1. Power Cycle the Drive:
    • As with most faults, start by fully powering down the drive, wait a few minutes, then power it back on. This may help clear temporary memory-related issues.
  2. Check for Loose Connections:
    • Verify that all connections to the SDCS-CON-4 control board are secure. Loose connections can sometimes cause intermittent issues that trigger memory errors.
