Error 8 in ABB DCS800 drive
Error 8 in ABB DCS800 drive indicates that the firmware is not running usually points to an issue with the drive's software or firmware. This can happen due to various reasons, such as corrupted firmware, communication issues during a firmware update, or internal drive errors.
Here are steps you can try to resolve this:
  1. Power Cycle the Drive: Start by powering off the drive completely, waiting for a few minutes, and then powering it back on. Sometimes a simple reset can clear minor software glitches.
  2. Check for Firmware Corruption: If the firmware was recently updated or if there was an interruption in the update, the firmware might be corrupted. Reinstall or update the firmware using ABB's firmware tool, ensuring the power is stable during the process.
  3. Verify Compatibility: Ensure that the firmware version installed is compatible with your drive’s hardware version. Mismatches can prevent the firmware from running.
  4. Inspect Drive Configuration: Incorrect parameter settings or configuration data can also cause firmware issues. Verify the configuration, or if possible, restore the drive to its factory settings.
