F515 M1FexOverCur Motor 1 field exciter overcurrent Fault In ABB DCS800
2 Users
10.3 K Views
How can resolve problem F515 M1FexOverCur Motor 1 field exciter over current Fault In ABB DCS800 ?
Check: In case this fault happens during field exciter autotuning deactivate the supervision by setting
M1FldOvrCurLev (30.13) = 135
Parameter settings of group 44 (field excitation: field current controller tuning)
1. Connections of field exciter
2. Insulation of cables and field winding
3. Resistance of field winding
(@jaivignesh1898)
Active Member
@click2electro sir by retadation of current the drive shows M1 flexovercurrent F515 fault how to resolve this sir
What is condition of fault means when fault comes after run command or coming continuously?
(@jaivignesh1898)
Active Member
@click2electro after full speed reached and then during when speed decrease from full speed  the fault occurs
Check motor data in group 99 and autotune motor field and armature.
(@jaivignesh1898)
Active Member
@click2electro autotune is successful in both motor field and armature
Check field current in parameter group 1
Parameter 1.30 - ..... Actual field current
And check in field terminal using clamp meter , compare both
What is the motor field current value in motor name plate ?
(@jaivignesh1898)
Active Member
  1. @click2electro Max 6.15 min 2.2
Page 1 / 2
