ABB DCS800 Drive
481
Oct 28, 2024 6:45 am
Cause : tacho polarity comes when the polarity of the analog tacho respectively pulse encoder [depending on M1SpeedFbSell (50.03)] is checked against the EMF.
F553 tacho polarity fault in ABB DCS800 drive indicates a "Tacho Polarity Fault." This means that the polarity of the tachometer signal is incorrect, causing the drive to misinterpret the motor's speed and direction.
- Verify the correct connection of the tachometer signal wires to the drive's input terminals.
- Visually inspect the tachometer sensor for any signs of damage or physical defects.
- Check the tachometer parameter settings, including polarity, scaling, and input type.
- Use a multimeter to measure the voltage and waveform of the tachometer signal.
