ABB DCS800 Drive
289
Oct 28, 2024 6:47 am
F554 tacho range fault in ABB DCS800 drive indicates that the tachometer signal received by the drive is outside the expected range.
- Use a multimeter to measure the voltage or frequency of the tachometer signal.
- Check the tachometer parameter settings, including the input type, range, and scaling.
- Visually inspect the tachometer sensor for any signs of damage or loose connections.
- Ensure that these settings are correct and compatible with the connected tachometer.
