2330 Residual current detected Fault In ABB DCS880
How can resolve problem 2330 Residual current detected Fault In ABB DCS880 ?
Programmable, see 31.18 Residual current detection type.
The drive has detected an unbalance typically due to a residual current in the motor or the motor cables. Sum of IL1, IL2, IL3 ≠ zero. See also A2B3.
Check:
The settings of 31.17 Residual current detection source, 31.18 Residual current detection type, 31.19 Residual current detection level and 31.20 Residual current detection delay.
The residual current transformer, if necessary change transformer or connected drive hardware.
The insulation resistances of motor and motor cables. Disconnect the mains, verify safe isolation from supply in armature and field circuits and make insulation tests for the complete installation.
