ABB DCS880 Drive
2
1,280
Dec 25, 2021 8:41 am
How can resolve problem 64B0 Memory unit detached Fault In ABB DCS880 ?
Dec 25, 2021 8:42 am
The memory unit was detached while the drive control unit is powered.
Switch off the power to the drive control unit and reinstall the memory unit.
In case the memory unit was not actually removed when the fault occurred,
check that the memory unit is properly inserted into its connector and its mounting screw is tight.
Then cycle the power to the drive or use 96.27 Control board boot.
