ABB DCS880 Drive
348
Oct 01, 2024 10:59 am
71A3 fault in ABB DCS880 drive indicates Mechanical brake not opened. This means the acknowledge signal at the DI for the mechanical brake opened (applied) stage is missing.
- Check the mechanical brake itself.
- Check the mechanical brake cable connections.
- Check the mechanical brake settings in group 44 Mechanical brake control.
- Check that the acknowledgement signal, if used, matches actual status of brake.
- Check the used digital inputs and outputs (groups 10 and 11).
