A2B3 Residual current detected warning In ABB DCS880
How can resolve problem A2B3 Residual current detected warning In ABB DCS880 ?
Programmable see : 31.18 Residual current detection type
The drive has detected an unbalance typically due to a residual
current in the motor or the motor cables. Sum of IL1, IL2, IL3 ≠ zero.
See also A2B3.
Check:
The settings of 31.17 Residual current detection source, 31.18
Residual current detection type, 31.19 Residual current
detection level and 31.20 Residual current detection delay.
The sum current transformer, if necessary change transformer
or connected drive hardware.
The insulation resistances of motor and motor cables.
Disconnect the mains, verify safe isolation from supply in
armature and field circuits and make insulation tests for the
complete installation.
The auxiliary code (format XXXY YYZZ).
Y YY identifies the power unit. In case of a hardparallel
configuration
