ABB DCS880 Drive
320
Sep 30, 2024 11:40 am
A492 warning in ABB DCS880 drive indicates motor temperature 2 measured/estimated error. This means measured/estimated motor temperature 2 has exceeded the warning level.
Check the following to correct the fault:
- The value of 35.03 Measured temperature 2.
- The real motor temperature. Let motor cool down and restart.
- The value of 35.23 Temperature 2 warning level.
- The cooling of the motor or other temperature measured equipment.
- The ambient conditions (e.g. ambient temperature).
- The airflow and fan operation.
- The motor fan supply voltage.
- The motor fan direction of rotation.
- The motor fan components.
- The motor cooling air inlet (e.g. filters).
- The motor cooling air outlet.
- The motor load and drive ratings.
- Inadmissible load cycle.
- The wiring of the temperature sensor.
- The resistance of the temperature sensor by measuring it.
