ABB DCS880 Drive
195
Sep 30, 2024 11:58 am
A7A1 warning in ABB DCS880 drive indicates mechanical brake not closed. This means the acknowledge signal for the mechanical brake closed (applied) stage at the DI is missing.
- Check the mechanical brake itself.
- Check the mechanical brake cable connections.
- Check the mechanical brake settings in group 44 Mechanical brake control.
- Check that the acknowledgement signal, if used, matches actual status of brake.
- Check the used digital inputs and outputs (groups 10 and 11).
