ABB ACS880 “Fault C...
ABB ACS880 “Fault Codes”
The ABB ACS880 is a series of industrial drives designed for various applications. These drives are equipped with comprehensive fault diagnostics to help users identify and troubleshoot issues efficiently. Here are fault codes that you may encounter with the ABB ACS880 drives:
  1. Overvoltage: This fault indicates that the DC bus voltage has exceeded the permissible level. It could be due to sudden load reduction or regeneration from the motor.
  2. Undervoltage: This fault occurs when the DC bus voltage drops below the acceptable level. Causes may include excessive regenerative energy or supply voltage fluctuations.
  3. Overcurrent: This fault indicates that the drive's output current has exceeded the maximum rated value. It could be caused by overloading, short circuits, or issues with the motor.
  4. Ground Fault: This fault occurs when there is an unintended connection between one of the motor phases and ground. It could result from insulation breakdown or wiring issues.
  5. Overtemperature: This fault indicates that the temperature of the drive or its components has exceeded the safe operating limits. It could be caused by inadequate cooling or excessive ambient temperature.
  6. Motor Phase Loss: This fault occurs when one of the motor phases is lost, leading to imbalance and potential damage to the motor.
  7. Encoder Fault: This fault is related to the feedback device (encoder) used for position control. It could indicate issues such as misalignment, damaged encoder, or wiring problems.
  8. Communication Fault: This fault indicates a communication problem between the drive and the control system or other devices. It could be due to cable issues, configuration errors, or device failures.
  9. Hardware Fault: This fault typically indicates a problem with the drive's hardware components such as the power module, control board, or sensors.
  10. Software Fault: This fault indicates a problem with the drive's firmware or software operation. It could be triggered by bugs, corruption, or compatibility issues.
