Fault 36 in allen bradley PowerFlex 700 drive
Cause : SW OverCurrent comes when drive output current has exceeded the 1 ms current rating. This rating is greater than the 3-second current rating and less than the hardware overcurrent fault level.
  • It is typically 200…250% of the drive continuous rating.
  • Check for excess load, improper DC boost setting.
  • DC brake volts set too high.
  • If enabled, check level of flux braking in parameter.
