Fault code 15 in allen bradley PowerFlex 755 drive
Cause : Load Loss comes when you run drive without motor or the rating of motor is small as compare to the drive rating.
  • Verify connections between motor and load.
  • Verify level and time requirements.
  • The output torque current is below the value programmed in P442 [Load Loss Level] for a time period greater than the time programmed in P443 [Load Loss Time].
