KEB COMBIVERT F6 Drive Overview
KEB COMBIVERT F6 Drive is a versatile drive controller that combines the functionality of a frequency inverter and a servo drive in one device. It’s designed for a wide range of applications requiring precise motor control, flexibility, and advanced safety features.
KEB COMBIVERT F6 Servo Drive image
Implement new machine concepts with enhanced performance, communication and integrated safety requirements. COMBIVERT F6 drive controllers are a frequency inverter and servo drive combined in one device and cover the entire power range from 2.2 kW to 450 kW. They control a wide range of motor technologies, with or without encoder operation, and – depending on the application – feature scalable, high-performance safety functions.
Catalog Manual
  • Functional consistency across the entire power range
  • High level of scalability:  A wide range of installation types and cooling modes
  • Various options for motors, encoders and communication
  • Precision and the highest level of repeatability
  • Integrated safety technology
  • Can be used in a wide range of applications
Power class 3-phase 230 V 3-phase 400 V
Power range 2.2 kW … 22 kW 4 kW … 450 kW
Rated currents 11 A … 85 A 9.5 A … 800 A
Peak currents (60 s) … 1.8 x In … 1.8 x In
Device variant COMPACT APPLICATION PRO
Fieldbus communication EtherCAT or VARAN EtherCAT, PROFINET (IRT), EtherNet/IP, POWERLINK, ModBus/TCP EtherCAT, PROFINET, ModBus/TCP
Communication interfaces CAN, diagnosis RS485/232 CAN, diagnosis RS485/232 CAN, diagnosis RS485/232, Ethernet, ModBus/RTU
Functional Safety STO STO, SBC and optional encoder-based speed/position-dependent safety functions STO, SBC and encoderless speed-dependent safety functions
Safety profile Safety over EtherCAT (FSoE), PROFIsafe Safety over EtherCAT (FSoE)
Encoder interfaces Multi-encoder Multi-encoder Multi-encoder optional
Type
Real-time Ethernet interface EtherCAT, PROFINET, EtherNet/IP, ModBus TCP, POWERLINK, VARAN
Communication interface CAN, Diagnostic interface RS485/232, Ethernet
Drive profile CiA 402 (IEC 61800-7)
Cyclic fieldbus cycle time EtherCAT up to 250 µs (125 µs on request) PROFINET, EtherNet/IP, ModBus/TCP, POWERLINK, VARAN up to 400 µs
Process data size EtherCAT up to 32 objects / 64 Byte, PROFINET, EtherNet/IP, ModBus/TCP, POWERLINK, VARAN up to 8 objects / 32 Byte
Fieldbus Ethernet diagnosis EoE (Ethernet over EtherCAT), PROFINET Ethernet channel, EtherNet/IP Ethernet diagnostic channel, Modbus/TCP Ethernet diagnostic channel
Serial diagnostic interface DIN 66019 for connection to diagnostic tools (e.g. COMBIVIS) or an operator
Operators / Adapters LCD operator, Ethernet operator, USB operator, Bluetooth adapter
Tools COMBIVIS 6, COMBIVIS studio 6, COMBIVIS mobile, COMBIVIS Command Line Interface
Basics Flexibility Highlights
    Sub-mounted braking resistor protection
U/f functionalities Operation of asynchronous, synchronous (SMM/IPM), synchronous reluctance motors, high-speed motors, high-torque motors, linear motors Blockade detection
Brake handling Evaluation of different types of encoders: TTL, HTL, Resolver, SinCos, EnDat, Hiperface, BiSS Cooling liquid management
Quick stop/error reaction Modes of operation: Velocity, Profile Position, Cyclic Sync Velocity, Cyclic Sync Position, Cyclic Sync Torque, Homing, Jog Mode Non-linear torque feed forward
Device memory/ Recipe management   Anti-cogging
PID controller   AiSCL (Asynchronous single current closed loop)
Motor/rotor identification   Power-off function (for all motor types)
Index positioning   Servo pump control
Position standstill controller   High output frequencies (variant if applicable)
Rotary table function   CAN-cross-communication (device variant APPLICATION and PRO)
Touch probe function
Drive software update
and much more.
