danfoss vlt drive fault codes
Danfoss VLT drives use a variety of fault codes to indicate different operational issues. Here's an overview of how to find Danfoss VLT drive fault codes and resources to help you troubleshoot them:
Locating Fault Codes:
The specific location to find the fault code depends on your Danfoss VLT drive model. Here are some common ways to access fault codes:
  • Drive Display: Most Danfoss VLT drives have a built-in display that shows the active fault code.
  • Human Machine Interface (HMI): If your drive is connected to an external HMI, the fault code might be displayed there.
  • Software: Danfoss provides PC-based software tools for monitoring and configuring VLT drives. These tools might also allow you to access fault code information.
Danfoss Resources:
Danfoss offers various resources to help you understand and troubleshoot fault codes for your specific VLT drive model. Here are some helpful starting points:
  • Drive User Manuals: The user manual for your specific Danfoss VLT drive model will provide detailed information on fault codes, including their descriptions and troubleshooting steps.
  • Danfoss VLT Online Support: Danfoss offers online support resources, including FAQs and troubleshooting guides, that might address your specific fault code.
Common Danfoss VLT Fault Codes:
While the specific fault codes will vary depending on the drive model, here are some commonly encountered fault codes on Danfoss VLT drives:
  • Overload (OL): This indicates an overload condition on the motor connected to the drive.
  • Overvoltage (OV): This indicates a voltage exceeding the acceptable limits at the drive's input.
  • Undervoltage (UV): This indicates a voltage below the acceptable limits at the drive's input.
  • Ground Fault (GF): This indicates a current leakage to ground.
  • Control Circuit Fault (CC): This indicates a malfunction within the drive's control circuits.
  • Communication Error (CE): This indicates an issue with communication between the drive and other devices.
Troubleshooting Tips:
Once you identify the fault code using the methods mentioned above, consult the user manual or Danfoss online resources for specific troubleshooting steps. Here are some general tips:
  • Safety First: Always ensure the power is off and the drive is safely isolated before performing any troubleshooting procedures.
  • Check for Obvious Issues: Start by inspecting for loose wiring, damaged components, or any external factors that might be causing the fault.
  • Reset the Drive (Optional): In some cases, a simple reset of the drive might clear the fault if it was a temporary glitch. However, if the fault persists, further troubleshooting is necessary.
  • Consult a Qualified Technician: If you're unsure about troubleshooting the fault yourself, consider contacting a qualified technician familiar with Danfoss VLT drives for further assistance.
By utilizing the Danfoss resources and following these tips, you should be able to identify and troubleshoot most common fault codes on your Danfoss VLT drive. Remember, referring to the specific user manual for your drive model is crucial for accurate troubleshooting steps and fault code descriptions.
