Danfoss Drives
549
Jan 17, 2024 11:56 am
Warning /Alarm in 29 VLT FC301/ FC302 : Heat sink temp - The maximum temperature of the heat sink is exceeded. The temperature fault is not reset until the temperature drops below a defined heat sink temperature. The trip and reset points are different based on the drive power size.
Check for the following conditions:
- The ambient temperature is too high.
- The motor cables are too long.
- Incorrect airflow clearance above and below the drive.
- Blocked airflow around the drive.
- Damaged heat sink fan.
- Dirty heat sink.
