4368 warning/fault in danfoss iC7 automation drive
Cause : Output Current High 0 comes when the output current of the drive has exceeded its normal range at low speed. Shock load or too fast acceleration with high-inertia loads can cause this fault.
  • Check that the motor size matches the drive and the motor data is correct.
  • Check that the motor shaft can be turned.
