Danfoss iC7-Automation & iC2-Micro Drive
476
Mar 07, 2024 11:43 am
Cause : Output Current High 1 comes when the output current of the drive has exceeded its normal range. Shock load or too fast acceleration with high-inertia loads can cause this fault.
- Check that the motor size matches the drive and the motor data is correct.
- Check that the motor shaft can be turned.
