4375 warning/fault in danfoss iC7 automation drive
Cause : Excessive Current Limiting comes when the output current of the drive has exceeded the current limit multiple times.
  • Check that the motor size matches the drive and the motor data is correct.
  • Check that the motor shaft can be turned.
