Danfoss iC7-Automation & iC2-Micro Drive
434
Mar 07, 2024 11:25 am
Cause : AMA Timeout comes when there is an internal fault in AMA. Try to restart AMA again a number of times, until the AMA is carried out. Note that repeated runs may heat the motor to a level where the resistance Rs and Rr are increased.
- Try to restart the AMA. Repeated restarts can overheat the motor.
