Danfoss iC7-Automation & iC2-Micro Drive
422
Mar 07, 2024 11:26 am
Cause : Current limit comes when the current is higher than the value in P 2.7.1 Output Current Limit % "Current limit" typically refers to a feature found in electronic devices, such as power supplies, motor controllers, or Variable Frequency Drives (VFDs).
This feature allows users to set a maximum limit on the amount of current that can flow through the device or system.
- Ensure that the motor data in P 4.2.2.1 Nominal Power to P 4.2.2.5 Nominal Speed is set correctly.
- Increase the current limit if necessary. Ensure that the system can operate safely at a higher limit.
