Fault 111 in danfoss vacon 20 drive
Cause : Temperature fault comes when the temperature of a critical component within the system has exceeded safe operating limits. This fault can arise due to various reasons, such as excessive ambient temperature, inadequate cooling, or issues with the internal components of the drive.
Here's how to address a temperature fault:
  1. Check Ambient Temperature: Evaluate the ambient temperature in the vicinity of the motor drive. High ambient temperatures can contribute to temperature faults. Ensure that the drive is installed in a well-ventilated area with adequate airflow to dissipate heat.
  2. Inspect Cooling Systems: Examine the cooling systems of the motor drive, including fans, heatsinks, and ventilation openings. Ensure that cooling components are functioning correctly and that airflow around the drive is unobstructed. Clean any dust or debris that may be blocking airflow.
  3. Monitor Internal Temperature: Use temperature monitoring tools or sensors to measure the temperature of critical components within the motor drive, such as the power electronics or control circuitry. Identify components that are operating at elevated temperatures and take corrective actions.
