Fault 57 in danfoss vacon 100X drive
Cause : Identification comes when identification run has failed. Run command was removed before completion of identification run. The motor is not connected to the AC drive. There is load on motor shaft.
  • If you're encountering an "identification run has failed" error, it likely pertains to a specific system or process where identification runs are conducted.
