Fault 69 in danfoss 100 flow drive
Cause : Fieldbus communication fault comes when the ID number that is used to map the values to fieldbus process data Out is not valid.
  • It is not possible to convert 1 or more values for Fieldbus Process Data Out.
  • There is an overflow when the values for Fieldbus Process Data Out (16-bit) are mapped and converted.
  1. Do a check of the parameters in Fieldbus Data Mapping menu.
  2. The type of the value is not specified. Do a check of the parameters in the Fieldbus Data Mapping menu.
  3. Do a check of the parameters in the Fieldbus Data Mapping menu.
