Danfoss Vacon 100X, 100 Flow & 100 Industrial Drive
279
Mar 07, 2024 10:07 am
Cause : Fieldbus communication fault comes when the ID number that is used to map the values to fieldbus process data Out is not valid.
- It is not possible to convert 1 or more values for Fieldbus Process Data Out.
- There is an overflow when the values for Fieldbus Process Data Out (16-bit) are mapped and converted.
- Do a check of the parameters in Fieldbus Data Mapping menu.
- The type of the value is not specified. Do a check of the parameters in the Fieldbus Data Mapping menu.
- Do a check of the parameters in the Fieldbus Data Mapping menu.
