Fault 22 in danfoss VACON NXL drive
Cause : EEPROM checksum fault comes when there's an issue with the data stored in the Electrically Erasable Programmable Read-Only Memory (EEPROM) of the drive. The EEPROM stores critical configuration settings and parameters for the drive's operation, and a checksum error indicates that the data stored in the EEPROM may have been corrupted or altered.
Here's how you can address an EEPROM checksum fault in your Danfoss Vacon 10 drive:
  1. Power cycle the drive: Sometimes, a temporary glitch can cause the EEPROM checksum fault. Try power cycling the drive by turning it off, waiting for a few minutes, and then turning it back on. This may clear the fault if it was caused by a transient issue.
  2. Reset the drive: Perform a factory reset or EEPROM reset on the drive to restore the EEPROM settings to their default values. Refer to the user manual or technical documentation provided by Danfoss for instructions on how to perform a reset.
  3. Check for firmware updates: Ensure that the drive's firmware is up to date. Sometimes, firmware bugs or compatibility issues can lead to EEPROM checksum faults. Updating the firmware to the latest version may resolve the issue.
