Fault 8 in danfoss VACON NXP drive
2 Users
Cause : System fault- A "system fault" in the context of a Vacon 20x drive typically refers to a fault or error condition detected by the drive's internal monitoring system. This fault indication can encompass a wide range of issues that may affect the proper functioning of the drive and its associated equipment.
(@hartf04)
New Member
so for the solution how to make the fault disappear and the vacon tool can work normally, because in my office place has a VACON NXP danfoss tool and every time it is turned on it always appears fault 8. Do you know the solution?
@hartf04 This is hardware fault - to correct fault need to repair or replace drive.
