Alarm 38 in danfoss VLT2800 drive
Cause : Internal fault number 1 comes when flash EEPROM fault on control card. If you encounter a "Flash EEPROM fault on control card" error message, it indicates a problem with the Electrically Erasable Programmable Read-Only Memory (EEPROM) on the control card of your equipment.
Here's how you can troubleshoot and potentially resolve this issue:
  1. Power Cycle: Sometimes, a simple power cycle can clear temporary faults. Turn off the power to the equipment, wait for a few minutes, then turn it back on. This can reset the control card and may resolve the EEPROM fault.
  2. Inspect for Physical Damage: Visually inspect the control card for any signs of physical damage such as burnt components, loose connections, or corrosion. If you notice any damage, it may indicate the source of the fault and require repair or replacement of the control card.
  3. Reprogram EEPROM: In some cases, reprogramming the EEPROM may resolve the fault. This typically requires specialized equipment and expertise. Refer to the equipment's manual or contact the manufacturer for instructions on how to reprogram the EEPROM.
  4. Replace Control Card: If the EEPROM fault persists despite troubleshooting attempts, it may be necessary to replace the control card. Contact the manufacturer or a qualified technician to obtain a replacement control card and perform the installation.
  5. Update Firmware: Sometimes, firmware updates can address known issues or bugs related to EEPROM functionality. Check if there are any firmware updates available for your equipment and follow the manufacturer's instructions to update the firmware.
