Alarm 45 in danfoss VLT2800 drive
Cause : Internal fault number 8 comes when I/O fault (digital input/output, relay or analog input/output). Encountering an "I/O fault" related to digital input/output (I/O), relay, or analog input/output (I/O) typically indicates an issue with the input or output signals of a device.
Here's how you can approach troubleshooting such a fault:
  1. Check Wiring Connections: Inspect the wiring connections for the affected I/O modules. Loose or improperly connected wires can cause intermittent faults or complete signal loss. Ensure that all connections are secure and properly terminated according to the device's documentation.
  2. Verify Power Supply: Ensure that the power supply to the I/O modules is stable and within the specified voltage range. Fluctuations or insufficient power can lead to unreliable operation or faults in the I/O signals.
