WARNING 33 in danfoss VLT2800 drive
Cause : Out of frequency range comes when the output frequency has reached Output frequency low limit (parameter 201) or Output frequency high limit (parameter 202).
  1. If the frequency converter is in Process regulation, closed loop (parameter 100) the warning will be active in the display.
  2. If the frequency converter is in another mode than Process regulation, closed loop, bit 008000 Out of frequency range in extended status word will be active, but there will not be a warning in the display.
