Danfoss VLT 2800 Drive
882
Feb 24, 2024 7:32 am
Cause : Over current comes when the inverter peak current limit (approximately 200% of the rated current) is exceeded. The warning lasts about 1.5 s, then the frequency converter trips and issues an alarm.
- This fault may be caused by shock loading or fast acceleration with high inertia loads.
- If extended mechanical brake control is selected, trip can be reset externally.
- Remove power and check if the motor shaft can be turned.
- Check that the motor size matches the frequency converter.
