Fault code 5 Earth fault in danfoss VLT 3000 drive
Cause : Earth fault comes when discharge from the output phases to earth, either in the cable between the VLT frequency converter and motor or in the motor (trip locked).
An earth fault, also known as a ground fault or an earth leakage fault, occurs when electrical current flows to the ground or any conductive surface other than the intended circuit path. It can happen due to insulation breakdown, damaged wiring, or faulty equipment, among other reasons.
