Danfoss VLT 5000 Drive
680
Feb 28, 2024 4:46 am
Cause : Heat sink temperature too high comes when the enclosure is IP 00 or IP 20/NEMA 1, the cut-out temperature of the heat-sink is 90°C. If IP 54 is used, the cut-out temperature is 80°C. The tolerance is ± 5°C.
- The temperature fault cannot be reset, until the temperature of the heat-sink is below 60°C.
- The fault could be the following:
- Ambient temperature too high
- Too long motor cable
- Too high switching frequency.
