WARNING/ALARM 10 in danfoss VLT8000
Cause : Motor over temperature comes when the motor is too hot. Select whether the frequency converter gives a warning or an alarm when the counter reaches 100%. The fault occurs when the motor is overloaded by more than 100% for too long.
  • Check for motor overheating.
  • Check if the motor is mechanically overloaded.
  • Check that the motor current set.
  • If an external fan is in use, check fan.
