DC-link Voltage Too Low (Error 0x3220/0x104) in danfoss DSD510
Cause : Incorrect mains input supply- Check that the supply voltage matches the allowed specification. When dealing with a DC-link voltage that's too low, it's crucial to diagnose the root cause accurately before attempting any corrective action. Here's a step-by-step guide to help you troubleshoot and resolve the issue:
  1. Check Input Power: Ensure that the input power to the DC-link is stable and within the specified range. Any fluctuations or deviations can affect the DC-link voltage.
  2. Inspect Power Supply: Verify the health and functionality of the power supply unit (PSU) or converter supplying power to the DC-link. If there are any issues with the PSU, such as overheating, component failure, or improper connections, it can lead to a low DC-link voltage.
  3. Examine Capacitors: Capacitors in the DC-link play a critical role in maintaining voltage stability. Check for any signs of bulging, leakage, or physical damage on the capacitors. Replace any faulty capacitors promptly.
  4. Inspect Connections: Ensure all connections in the DC-link circuit are secure and free from corrosion or damage. Loose connections can lead to voltage drops and instability.
  5. Diagnose Faulty Components: Test individual components such as diodes, transistors, and voltage regulators within the DC-link circuit to identify any faulty components causing the voltage drop. Replace or repair as necessary.
  6. Check Control Circuitry: Faults in the control circuitry can also contribute to low DC-link voltage. Inspect the control circuit components, including sensors, feedback loops, and control algorithms, to identify any malfunctions.
