Danfoss VLT FCD300, FCD 302 & DSD 510 Decentral Drive
401
Mar 04, 2024 12:00 pm
Cause : Out of frequency range comes when the output frequency has reached Output frequency low limit (parameter 201) or Output frequency high limit (parameter 202).
- If the frequency converter is in Process regulation, closed loop (parameter 100) the warning will be active in the display.
- If the frequency converter is in another mode than Process regulation, closed loop, bit 008000 Out of frequency range in extended status word will be active, but there will not be a warning in the display.
