Danfoss VLT FCD300, FCD 302 & DSD 510 Decentral Drive
548
Feb 29, 2024 12:32 pm
Cause : Motor overload temperature comes when the motor is too hot. Select whether the frequency converter gives a warning or an alarm when the counter reaches 100%. The fault occurs when the motor is overloaded by more than 100% for too long.
- Check for motor overheating.
- Check if the motor is mechanically overloaded.
- Check that the motor current set in Motor Current parameter
- If an external fan is in use, check fan
