Danfoss VLT FCD300, FCD 302 & DSD 510 Decentral Drive
233
Mar 04, 2024 12:02 pm
Cause : Overtemperature comes when the temperature inside the power module rises above 75 - 85 °C (depending on the device) the frequency converter will emit a warning, and the motor will continue to run unchanged.
- If the temperature continues to rise, the switch frequency is reduced automatically. See Temperature-dependent switching frequency.
- If the temperature inside the power module rises above 92 - 100 °C (depending on the unit) the frequency converter will cut out.
- The temperature fault cannot be reset until the temperature has dropped to below 70 °C. The tolerance is ± 5 °C.
The temperature can be caused by the following:
- The ambient temperature too high.
- Motor cable too long.
- Too high mains voltage.
