ALARM 11 in danfoss VLT FCM300
Cause : Motor thermistor over temp comes a thermistor is mounted and parameter 128 is set to Enable [1], the FCM 300 will trip if the motor gets too hot.
  • Check for motor overheating.
  • Check if the motor is mechanically overloaded
  • If using a thermal switch or thermistor, check that the programming if matches sensor wiring.
