Danfoss VLT LD 302 Lift Drive
545
Feb 24, 2024 6:43 am
Cause : Brake Resistor Power Limit - The power transmitted to the brake resistor is calculated as a mean value over the last 120 s of run time. The calculation is based on the DC-link voltage and the brake resistor value set in parameter Brake Resistor (ohm).
- The calculation is based on the intermediate circuit voltage and the brake resistance value.
- The warning is active when the dissipated braking is higher than 90% of the brake resistance power.
